any tips on hooking trans to engine??-help
Old Oct 1, 2007 | 08:15 PM
beige97camry's Avatar
Default any tips on hooking trans to engine??-help
both out of car and need to hook them together, any tips to make it easier to get bolted up with minimum trouble.
Old Oct 5, 2007 | 06:48 PM
marv8's Avatar
Default RE: any tips on hooking trans to engine??-help
Don't force them together( as in pulling them together with a longer bolt) you may/willdamage it. It has to start and twist in, get a friend to help. Check the two fluid compartments assuming its like the 94-96 trans you may have lost some fluid rolling it around while getting it in.
1BluSE
May 12, 2013 10:52 PM
Nick G
Jun 26, 2012 10:30 AM
KirkwoodKid2010
Oct 18, 2009 01:28 PM
K_Watson
May 25, 2008 09:30 PM
