Is ATF+4 Compatible with 2001 Toyota Camry
Old Jan 8, 2020 | 04:30 PM
whealthy's Avatar
Smile Is ATF+4 Compatible with 2001 Toyota Camry
Hello. I just picked up a 2001 Toyota Camry LE Gallery Edition. It has the 3.0L V6 in it with an automatic transmission with Over drive. The transmission is leaking. I am trying to figure out where the leak is coming from. I formerly had a 1996 Oldsmobile 88 and have several quarts of ATF+4. I see the Toyota Manual says to use Dextron III. I was wondering if I could use the ATF+4 in the transmission, either temporarily while I locate the leak or even as a permanent replacement. From what I understand the ATF+4 is superior to the Dexron III but I am far from an expert in vehicles with automatic transmissions.
Thanks in advance for your help.
Old Jan 8, 2020 | 09:57 PM
ATF+4 appears to be for Chrysler products.
92_2.2
Oct 22, 2019 09:06 PM
Dan400Man
Mar 12, 2016 11:37 PM
joestimec
Jun 12, 2010 12:32 PM
tkhockey93
Nov 16, 2009 12:30 AM
camry1326
Mar 7, 2008 01:15 AM
