hello newbie in here i have a issue with 01 camry v6
Old Apr 15, 2012 | 05:00 PM
passat for me's Avatar
Default hello newbie in here i have a issue with 01 camry v6
I believe the code refers to purge valve sensor anyone know about this ?
Old Apr 15, 2012 | 11:07 PM
What was the exact code number?
Old Apr 17, 2012 | 07:51 PM
PO440,PO441,PO446 were the codes that came up tonight
vapor canister or vapor solenoid I already replace the fuel cap
the canister is dealer only part I think it s about $ 325 I m going to try to look under there see if there s a loose hose or connector crossing my finger on being something loose
Old Apr 17, 2012 | 09:37 PM
Yes could be a solenoid.
Toyota has a service bulletin on this which may apply. EG013-03. Inoperative
Canister Closed Valve Vacuum Switching Valve. P/N might be 90910–12206
Although the warranty has expired a dealer should be able to tell you if the TSB was every applied to the car based on its VIN.
This is a DC powered switch the open/closes a vacuum line. The switch type is called a VSV.
There are two VSV's one for the EVAP system canister, the other for the vapor pressure sensor. The canister VSV hose connects to the engine.
Could also be the vapor pressure sensor, cracked canister, damaged hoses, fuel tank overflow valve leaking.
You can test VSV's by applying 12V and determining if the valve works.
After market VSV's may be available. If buying from a dealer shop around on the internet where dealer parts are available at lower prices.
addictedz
Jul 10, 2013 01:22 AM
bodykits
Apr 24, 2009 01:09 AM
v6kamree
Dec 20, 2005 03:29 AM
