help-can't seperate eng from auto trans
Old Aug 16, 2007 | 06:29 PM
beige97camry's Avatar
Default help-can't seperate eng from auto trans
motor threw part of rod thru front of block. can't turn motor over as I think rod wedged in tight. need to separate auto trans from motor to pull motor, can't turn flywheel so I can unbolt flexplate from converter. any ideas how to do this or turn motor over so I can remove converter bolts?????????? do I have to pull trans with motor now??? thanks.
mike
70rrclone
Mar 14, 2010 06:19 PM
beige97camry
Aug 26, 2007 03:36 PM
beige97camry
Aug 21, 2007 09:59 PM
