hi im new to camry forums
Old Jul 8, 2008 | 09:32 PM
90 camry 5speed's Avatar
Default hi im new to camry forums
hi im new around here i was wondering ,i want topunch out my 2.0 5 speed
any sugesstion s i was thinking about swaping it out for a 2.2 out of a celica & boreing and strokeing the block 30 overbore and raiseing the compression , any suggestions.....................
Old Jul 8, 2008 | 09:54 PM
beunos24's Avatar
Default RE: hi im new to camry forums
I've got a better idea. Scratch that celica engine and go for a mr2 engine. Its twin turbo and all you have to do is change those turbos and I seriously think if you change the two turbos into 2 t3 turbos you will be hitting 350 plus horses easy. And that should be with low amounts of boost. I'm not to sure how that would be done but I think you could smoke a ton of cars with that set up
Old Jul 8, 2008 | 10:03 PM
how much would that cost? im also new to the import scene , i been restoreing classic fords since i was 12. so i dont know nothing about toyotas ,hondas ,etc......
Old Jul 8, 2008 | 10:15 PM
beunos24's Avatar
Well you might wana check ebay for the engine. There's a company by me that sells them on ebay and I went down there to make sure everything was legit. I think if you get a good one of ebay with transmission and ecu it should run you about 3g. It will be expensive but well worth it and that power should satisfy you until you change the turbos. And you'll also have to change the exhaust pipe to 3 inchs and get a turbo muffler. They have bigger diameters to allow all the exhaust out
04CAMRY
Jul 7, 2008 09:24 AM
danomatic93
Jan 1, 2008 01:19 AM
salsacam04
Jul 13, 2007 06:47 PM
supraman7288
Apr 1, 2007 01:28 AM
Dan_Lemur
Jun 8, 2005 03:18 AM
