Need help problem with catalytic
Old Aug 17, 2012 | 12:00 PM
JNarvaez's Avatar
Default Need help problem with catalytic
My car turn on the check engine light when I check the scan tell me that have problem with the catalytic but is so expensive so they tell me the better option is to remove the 3 catalytic is a good idea? please tell me the pro and con... thanks
Old Aug 18, 2012 | 11:47 AM
What is the code(s).
The converter condition is monitored 02 or A/F sensors installed into the exhaust pipe. One is installed before the converter and one after converter. The sensors compare readings and based on the results determine the condition of the converter.
Removing the converter without doing something about the sensors will not help.
tvsdprasad
May 20, 2015 02:28 AM
Whitese7en
Jul 16, 2013 06:35 PM
rollingthunder6
Dec 30, 2009 09:15 PM
ntxgb
Feb 9, 2009 03:37 PM
camry313
Mar 31, 2008 08:23 AM
