09 Camry pressing gas pedal has no effect
Old Aug 12, 2012 | 02:25 AM
spice's Avatar
Default 09 Camry pressing gas pedal has no effect
Pressing the gas pedal on my 2009 Camry has no effect. The engine starts fine, but the car won't speed; it just moves along very, vey slowly.
It has 60+K miles with normal servicing.
Any insights will be greatly appreciated.
Old Aug 12, 2012 | 12:13 PM
The engine may use an electric throttle. In this case the throttle pedal is not connected to the engines throttle by a steel cable but electrical wires that operate an electric motor to move the throttle.
If the throttle pedal or motor fail the engine goes into a get-home-mode to allow getting off the road, getting home, getting to the repair shop, etc.
Old Aug 16, 2012 | 07:47 PM
spice's Avatar
Thank you toyomoho.
My son was the one driving the car when the "pedal not throttling" issue arose. He tells me he had gotten the battery jump-started just prior.
It turns out one of the fuses controlling fuel had broken probably as a result of improper connection of cables when jump-starting.
Replacing the fuse fixed the problem.
Old Aug 18, 2012 | 12:43 PM
Good job!
Thanks for posting back with the fix.
i405
Sep 2, 2009 04:10 PM
jolson1383
Mar 6, 2009 11:15 AM
dragon002
15
Apr 24, 2008 02:01 PM
JanSport40
Mar 6, 2007 03:15 PM
lilnuke
Jan 18, 2007 11:38 PM
