possible camry rally car?
Old May 11, 2008 | 10:48 PM
kb1oju's Avatar
Default possible camry rally car?
Hello, i am new to the camry forums so please bare with
im looking to do a little bit of rally cross with my camry, its a 95 4cyl 5 speed standard, and would love to get into the sport. what would you recommend (other than buying a subaru or a mitsu) to help my camry rally better?
thank you for your thoughts, itd be greatly appreciated
Old May 12, 2008 | 12:04 AM
Camryhillcar's Avatar
Default RE: possible camry rally car?
I would by a car that is made to rally like a STI. Because it is hard to get out of mud with 67hp and front wheels just spinning. But you could put some swamp tires and a lift kit. Let me know how it works out let us see some action shots of it stuck.
Don
Old May 13, 2008 | 06:33 AM
sexiewasd's Avatar
Good set of progressive rate springs and shocks, stiff sway bars and bushings, as well as carbon skid plates and dirt/winter tires, then strip the interior and replace the wheel bearings, tie rod ends and clutch plates every year. There isn't much your going to be able to do to get enough hp, you could get rid of any Air con and heat, get a smaller alternator with an underdrive pully and a smaller battery, and get rid of the catalytic converter and muffler. Weight reduction is your best bet but you would have to be very aggressive with it in order to compete.
ohh and don't forget a roll cage, even if you don't roll it stiffens the chassis a lot.
Mxnagy221
May 20, 2015 06:46 PM
Nathan_modball
Feb 28, 2011 06:31 AM
emaxxman
Mar 12, 2007 05:26 AM
