99 camry oil light issue, need input quick
Old May 12, 2008 | 10:58 PM
RonP's Avatar
Default 99 camry oil light issue, need input quick
Guys, just joined the forum. I need some advice. I am buying a 99 camry le tomorrow for my 16 year old to drive. the car is in great shape and drives awesome. I noticed while at a stop sign, the oil light flickers. I asked the gentlemen about it and he said it was normal and even showed me a para in the owners manual that stated that it was normal and as long as it went out as soon as you accelerated some, it was fine. I just wanted a sanity check from some folks who know these cars better than I.
thanks
Old May 13, 2008 | 12:58 PM
Default RE: 99 camry oil light issue, need input quick
There is a paragraph in the owners manual on this, did you read it?
Off hand would not say this is normal for most Camry. The oil pressure light comes on at a very low oil pressure.
Some of these engines had issues with sludge build up, not the majority just enough to make one want to pull the valve cover and take a look for sludge.
Suggest before purchase to have a shop install a pressure gauge then determine just what the pressure is.
For the 4 cylinder idle oil pressure should be at least 4.3 psi at idle and at 3000 RPM should be between 36 and 71 psi. If going to a shop, have the remove the valve cover and look for sludge. This is a quick task to do.
XxSicRokerxX
May 4, 2015 11:20 PM
The_Editor
Jan 6, 2012 09:48 PM
nol1dwa
Nov 15, 2008 12:04 PM
cowabunga
Nov 27, 2007 02:21 AM
1993Camry
Feb 13, 2007 08:56 AM
