Replaced IAC, now won't start
Old Mar 1, 2020 | 07:00 PM
bckaaa's Avatar
Default Replaced IAC, now won't start
I have a 93 2.2 LE. I pulled off the throttle body and then removed the IAC. I put on a brand new IAC and put everything back in its place. I started the car and after about 2 minutes of idling it died. Now it will not start at all. I cleaned the IAC sensor and the MAF sensor. I turned the key to on for 2 minutes and then off as I was told this reset the ECU and still nothing. I am stumped, any ideas?
Old Mar 2, 2020 | 02:42 PM
Did you disconnect the battery when installing the IAC valve? Disconnecting the battery can cause issues that will eventually self correct. Turning ign key on for long periods does nothing and is not recommended.
Did the engine start and operate OK with the old part?
Make sure the IAC valve has coolant running through it?
Could be a bad valve. See private message.
duhitsrandy
Aug 26, 2013 06:08 AM
sherrilynn
Nov 3, 2011 07:49 AM
brianjrealtor
Jun 4, 2011 09:44 PM
99CamryGuy
Oct 2, 2010 07:14 PM
mjnrite1
Aug 23, 2008 04:33 PM
