95 Camry stall when stoping or idling..
Okay, my 95 camry Le just became symptomatic with these problems. Car starts and runs fine. After driving for around 15 or 20 minutes it starts to run slightly rougher but only when slowing down to come to a stop. It will then die at stop. When atempting to restart it takes several attempts. Once restarted it seems to run fine again. Sometimes I can drive longer and futher before it happens again and sometimes it happens within 15-25 minutes. Any ideas where I should start?? Thanks for any help you can lend.
Idle speed is controlled by the IAC valve. Cleaning the valve may help the problem. An internet search will produce hits on cleaning the valve.
Try "cleaning 5SFE IAC valve".
Sometimes the coolant temperature sensor for engine computer can go bad causing strange problems.
Thanks Joey, yesterday we had a new symptom. Just before dying, the car reved up to over 4000 rpms without foot being on the gas pedal. I will check out your suggestions hopefully that will help.
Sherri
Sherri
IAC valve controls idle speed.
Make sure for some reason the throttle plate is not moving. It is controlled by a cable going to the cruise control box then another cable gone from the box to the throttle peddle. This would be very strange but never know. If the throttle is not moving and in the idle position (closed) the IAC valve would be suspect.
Hi, i have a similar problem. I recently cleaned the EGR valve, now the car starts and dies. I need to keep the foot on the gas for a couple seconds then it stays running. I also have check engine light. Someone told me it was the map sensor. i also noticed the car does not have pick up and i smell crude gas. Please help this is my first car. Any ideas, i would greatly appreciate.
thank you for the quick reply. I didn't remove the intake. I recently changed the sparks plugs, cables rotor and cap. the car continues to give problems. for example. if i tap on the gas pedal the car wants to die meaning the rpms go very low and go up to normal. in addition that car does not have pick when i accelerate it takes very long time to pick up the speed. any additional help i would greatly appreciated.
Any codes?
A bad O2 sensor could cause it to run sluggish and smell like gas since the ECU thinks the car is running lean it dumps more fuel to the injectors.
If you're not getting the code though it's likely something else.
dsmith222
04-08-2011 09:43 PM
