Sudden loss of power to wheels
If no Park when the gear selector is in Park. Check for a broken gear selector cable.
Look under the hood for a push/pull cable going to the radiator side of the trans. Follow the cable to the trans where there is a shift lever connected to the push/pull cable.
Have someone move the gear selector between gears selections while you watch the lever. It should move (rotate) with the gear selector movement. If not the cable is broken.
emma85123
Apr 26, 2013 01:47 AM
BondJamesBond
Sep 15, 2009 06:02 PM
