Throttle body
Old Sep 5, 2012 | 09:16 PM
05cam's Avatar
Default Throttle body
Hey everyone....This post is for anyone whom can answer my problem..
I have an 05 camry...The throttle body has been stuck in limp mode and sometimes the Cel light goes on and then goes off and problem persist as far as engine dying anything over 2k rpms....
I know they have redesigned this part so moisture doesnt get in and want about 1,000$ for it...My question i guess is there a way to drill the pop rivets on the electric motor on the throttle body and clean it out and re pop rivet it back in place and fix it myself? I know buying a used one i could just find the same problem again.
I noticed spraying throttle body cleaner inside the tb itself kind of helps, ive done it before and got about another 10k out of it. Now I think its shot and and a simple cleaning wont help anymore...
It has 185,000 miles 05 camry with I-4...
Just would hate to spend a grand on something if i can fix it myself i suppose...
Has anyone done this before? Is it spring loaded? is there a diagram ?
Old Sep 6, 2012 | 12:06 AM
full house's Avatar
that one seem to be tough and would cost you a lot.
Not sure if this thing happen to me years ago...
What happened I spent a lot but the problem still occur after a few years.
Old Sep 6, 2012 | 10:31 AM
Also check at the Toyotanation website.
Suggest using something like CRC brand electrical contact cleaner rather then throttle body cleaner.
Toyota's has only info for remove and replace.
If needed to buy the part new shop online at sites such as below that sell parts at a discount. If calling identify yourself as an internet customer to receive the discount.
"Toyota Parts" | "Toyota Accessories" | Parts.TitusWillToyota.com
Old Sep 6, 2012 | 11:34 AM
05cam's Avatar
If I do go about replacing it with a new one, whats the part number or what I should look for as far as one that has been corrected to seal the moisture out? Or rather any specific numbers on the part itself I should look for? Would hate to spend 700+$'s on a part that was factory original rather than one that has been corrected if that makes sense?
I know scion tc, Rav4, and Solara all share the same engine...But if I buy a used one that came off a rav4 or tc will it plug and play? Will the ecu read its not the correct part thus not allowing it to function? Thats my main concern.
I know its a common problem and from what ive learned its due to moisture....Is this correct? Or is it cause of another reason? Ive read where the failure has happend on motors with 40,000 miles....How does that explain ive got 185k out of mine? haha just seems odd the post I read are failures with less than 100k...Will the new part fail too or has it been corrected to not fail....
Old Sep 6, 2012 | 02:46 PM
05cam's Avatar
Also how do I know its not the pedal tps sensor itself? other than the likely culprit of the throttle body being a common problem
Old Sep 6, 2012 | 05:08 PM
boricua's Avatar
wish code you got when CEL was on
Old Sep 6, 2012 | 11:42 PM
05cam's Avatar
I think it was 2112....which would of been actuator stuck closed ...which answers my question...im so smart im stupid lol..
That answers my last post...i still would like to know if theres any answers for the post before that at 434 pm
Old Sep 7, 2012 | 05:55 PM
boricua's Avatar
when purchasing a used one make sure that the part number mach.
Old Sep 7, 2012 | 08:37 PM
05cam's Avatar
OK i found a used one off a 2006 scion tc....will this fit my car?
What years are interchangable? And non interchangable?
chrisdupe
Aug 5, 2009 12:30 AM
OntarioCamry
Jun 22, 2009 12:34 AM
Octapulse
May 5, 2008 07:25 AM
bassposse
Sep 6, 2007 12:18 AM
marc780
Apr 10, 2006 06:22 PM
