Throttle body gasket remover?
1993 Camry LE...
I plan on removing and cleaning the IAC valve this weekend. I plan on removing the throttle body along with it for easy removal and reinstall.
Previously, I had removed and cleaned the EGR valve. It has a small papar gasket that had eroded and fell apart and was still stuck in several places to the EGR valve. I had to scrape the gasket off manually and it was hard to remove completely and it took a while to remove delicately not to scratch the aluminum parts.
it looks as though the TB gasket is of the same material and i'm concerned it has eroded and will stick in several areas. What can I use to spray or scrape it off effectively without damaging the aluminum surface areas of the TB and Intake manifold??
thanks!
Brian
thanks!
Brian
marc780
Apr 10, 2006 06:22 PM
