What is this part that is leaking in my 2005 Camry?
Old Mar 3, 2022 | 05:43 PM
GID's Avatar
GID
Default What is this part that is leaking in my 2005 Camry?
I noticed some brownish stains in my driveway where I normally park. I checked underneath the car and saw a cylinder near my ATF in/out lines that the leaks were coming from. I am not sure what this part is or what exactly it is that is leaking. Does anyone know what this is?
2005 Camry LE
4 cyl
AT
Where the leak is coming from
Old Mar 4, 2022 | 12:35 PM
Suggest comparing the leaking oil with engine, trans and power steering fluid (if the car still has hydraulic power steering and not electric). Smell the fluid as this can also be an indicator.
Toyota may have used hydraulic engine mounts which contain fluid. This mount is the black rubber covered item circled. The mount is self contained like a shock absorber. The mount can start to fail and leak. Check around the mount for internal leakage.
If a bad mount and handy with tools, its an easy DIY repair.
Old Mar 6, 2022 | 12:09 AM
GID's Avatar
GID
Thank you for the info. So that is the hydraulic mount and the leak is definitely coming from that. I do have the tools to fix it so I will go that route.
bridav0408
Mar 15, 2020 08:32 AM
Leah Nutt
Oct 11, 2015 12:51 AM
mnfmkf
Dec 17, 2012 12:32 PM
pramod
Sep 13, 2010 08:05 PM
stomper
Mar 17, 2010 12:19 AM
