where does this connector go?
Toyota uses a lot of different style and color plugs.
If the number of wires and colors is not enough (should be but).
While your in there a close up of the front and side of the plug with rubber shield pulled back can also narrow down things down.
In the engine compartment:
The power steering oil pressure switch has a single red/white wire going to it. The plug appears to be in the area of your photo. So, check the power steering system for the opposite plug.
Ign coil No 1 has a red/white wire and a white/red wire,this is most likely a 2 wire plug.
CDU1MALE
May 28, 2009 12:46 PM
NorthWet
Jun 8, 2007 01:08 AM
