'00 V6, hesitation on accelleration
Old Jun 9, 2009 | 05:49 PM
xci.ed6's Avatar
Default '00 V6, hesitation on accelleration
I'm looking at this camry (133k) for a friend of mine, and it's giving me some trouble.
I've got a CEL with a PO420, which is possibly related, but I want to check my other options first. Also the TRAC OFF & ABS lights are on, but my scanner only does engine codes.
Anything over 30% throttle and the car backfires and sputters, I'd think fuel pressure or plugged exhaust, but it will maintain speed once it gets there. Fuel trims are normal, MAP & MAF signals are normal. Plugs & wires look good.
This all leads me to thinking the cat might have melted down, but I've never seen a camry melt a cat before.
I'm going to go drop the exhaust and go for a drive to see if it goes away, anyone have any other ideas? I'm skeptical that the exhaust is going to be my problem.
Old Jun 9, 2009 | 07:31 PM
xci.ed6's Avatar
The exhaust was not the problem, So I cleared the codes, and it did not come back.
I forgot to check the TPS last time, and the TPS only ranges from 11% to 71% so now I'm focusing on that.
It's wierd, it gives normal power sometimes above 30%, but mostly it has nothing and just misses. When it is missing the short term fuel trims drop, as expected so I know the fuel system and O2 sensors are working good. It makes it seem like an ignition problem, but I can't find anything wrong with the ignition system.
Do the V6's have MAP sensors, or just the I4? I haven't seen anything that looks like a MAP, and it does not show up on my PID list.
Thanks,
-Dustin
BTW, the shop he took it to wanted to change the MAF, but could not give a reason.
Old Jun 22, 2009 | 02:39 PM
xci.ed6's Avatar
Wow, yeah, cat was melted. Fixed that, then retested the ignition, plug wires were bad. New plugs & wires fixed some of the problem. Still pretty bad, so I'm putting in a new TPS tonight.
I hate trying to fix cars w/ no MIL driveability concerns w/o OEM tools
Old Jan 11, 2010 | 09:17 AM
one_lucky_monkey's Avatar
Did you fix it by putting in a new TPS?
rkimes11
Feb 21, 2010 05:40 PM
ckelner
Apr 20, 2009 07:09 PM
flyboy34
Jul 6, 2008 10:22 PM
91 toyota
Dec 27, 2007 10:45 AM
nicole_fl
May 24, 2007 09:51 PM
