02 Camry SE V6
Old Mar 27, 2008 | 08:27 AM
vailitrev's Avatar
Default 02 Camry SE V6
On my 02 when running at a constant speed it stumbles alittle like it was starving for fule or missing, any Ideas?
There are no engine lights on, I run injector cleaner through it when the oil is changed, I have not checked the plugs yet.
Old Mar 27, 2008 | 10:17 AM
Default RE: 02 Camry SE V6
Can you describe the problem a little more. A high speed miss when hwy driving, lack of power when going up hills, how is the MPG, car starts and idle OK, constant problem or every once in a while.
Old Apr 10, 2008 | 04:16 AM
vailitrev's Avatar
The idle seems off, it is around 750 RPM and does not go up when you put it in drive. The problem occurs between 1500 and 2000 RPM, for example you are going 40 MPH and you are trying to maintain that speed, you have your foot very light on the pedal and it seems to miss between the said RPMs, above 2000 RPMs it runs fine????????????
Old Apr 10, 2008 | 06:18 AM
pedro's Avatar
ORIGINAL: vailitrev
Normal
If it appears to be hunting and not missing I'd say it's the TPS
