1990 Camry A/C Problem
Old May 30, 2012 | 10:00 PM
RobtLee's Avatar
Question 1990 Camry A/C Problem
My daughter's Camry is blowing warm air from the vents. The A/C controls are set on high and cold, the compressor clutch is turning, all the fuses are good, and I can't figure it out. I have a can of 134a with the removeable hose and gauge and when I connected it, the gauge showed 0 pressure. When I gave it a short shot of 134a, the gauge shows an overcharge. Very weird. I've used this setup on my Jaguar, so I know it is okay. Any thoughts on what the problem is?
Old May 30, 2012 | 10:25 PM
full house's Avatar
maybe you did something to make overcharge it usually turns out good doing the right procedure.
Old May 31, 2012 | 05:35 AM
RobtLee's Avatar
Don't know what I could have done. All I did was connect the hose, checked for system pressure, gave it a half-second squeeze on the charging handle, and rechecked the system pressure.
Could this be a stuck expansion valve? I saw that in another thread.
Old May 31, 2012 | 09:05 AM
boricua's Avatar
make sure the compressor is running , inspect a/c magnetic clucht relay .
Jilek
Aug 9, 2022 01:49 PM
JBW
May 15, 2013 08:47 AM
1990_4Cyl_LE
Aug 29, 2012 11:55 PM
tri1968
Jul 23, 2012 10:14 AM
sposey
Oct 25, 2007 09:22 PM
