1993 Toyota Camry Water Outler
Hello,
My name is David and I own a 1993 Toyota Camry XLE V6 3.0L. My water outler at the cap started leaking water because the water outlet where the cap meet is corroded. I been to Autozone and Checkers and they cant seem to find the correct water outlet that I need. Its been like this for 3 weeks and it keeps leaking water. Heres a picture. Can anyone help me identify the part so I can finally buy it?
Thanks
Thanks
Might try posting at the Toyotanation website, a much larger membership.
What engine model, the Camry may have offered two V6 engine this year?
Might call a Toyota dealer.
How bad is the corrosion? Can you clean up the area (reface) with a file, a belt sander?
Have you thought about using something like automotive silicone seal or Aviation Form-A-Gasket, making a thicker gasket or stacking more then one gasket up (along with using something like Aviation Form-A-Gasket?
You might be able to build up the corroded area with something like JB weld then file it smooth again.
tvsdprasad
May 21, 2015 02:42 AM
J2Performance
Jan 25, 2008 11:54 AM
J2Performance
Dec 17, 2007 03:57 PM
J2Performance
Dec 12, 2007 06:24 PM
