1994 Camry 2.2 no spark
Old Feb 27, 2011 | 03:44 PM
Jake7887's Avatar
Default 1994 Camry 2.2 no spark
I have a 1994 camry with no fire to plug wires. The Cap looks fine and the button is moving. I checked the timing belt and it looks great, I also checked all fuses and relays. I am stuck anyone have any info that mighjt help me out here.:conf used:
Old Feb 27, 2011 | 05:46 PM
Check the following:
-MA2 fuse in engine compartment fuse box.
-Ign spark at high voltage cable from the coil.
-12V at the positive power terminal of coil.
-Ign coil for cracks.
The AutoZone website at www.autozone.com has info to check the coil and distributor in the sites vehicle repair section.
Old Feb 27, 2011 | 09:15 PM
full house's Avatar
that's too complicated on my part need to see and know exactly what happen to find the cause of it... it seem that wires are working perfectly and can't figure it out what causes it.
Old Mar 1, 2011 | 12:28 PM
Jake7887's Avatar
Where is the ignition coil located i am unable to locate it i traced the wires on distributor to a pig tail. I cant find coil neither can my dad.
Old Mar 2, 2011 | 09:53 AM
If the distributor cap does not have a place for coil cable, the coil is built into the distributor. The coil is located on the same side of the distributor that the housing attach arm is.
If there is a space for the ign cable (5 cable plug-ins on the cap) the coil is located in front of the drivers side shock tower. The coil is positioned vertically, the ign cable plugs in vertically.
Old Mar 3, 2011 | 03:35 PM
Jake7887's Avatar
Thanks going to check it out now
Thanks for the in detail info
manty1
Apr 10, 2013 04:54 AM
organica
Jul 17, 2011 09:15 AM
micjamkil
May 19, 2011 07:25 PM
feanor70115
Feb 4, 2008 01:35 AM
feanor70115
Feb 1, 2008 06:46 AM
