1995 Camry Window not working
Old Oct 9, 2011 | 01:11 PM
jfirusta's Avatar
Default 1995 Camry Window not working
Hello everyone, I know window problems are common in the Camry, I know several people who with Camrys and they all have window problems. Mine is odd, all of the windows work except for the rear driver's side window. It won't work from the driver's switch, or the individual door switch. Is this the motor? I do like having use of all windows, so fixing this is preferred. Anyone have any tips? Thanks in advance.
Old Oct 9, 2011 | 08:09 PM
Could be broken wires running between the drivers door and chassis. The motor or passengers switch.
The passenger power window switch can be pried out with a taped flat screw driver. Pry the longer switch side that faces the passenger.
Once out there should be a plug having two wires that runs to the motor.
Apply 12V to the two terminals of the plug. If you want reverse operation of the window reverse power polarity to the plug.
If the window does not work the motor is the problem.
jmac247
Apr 13, 2022 08:08 AM
camrynyer
May 13, 2014 04:34 PM
mx3man83
Jul 4, 2009 11:24 PM
kenl000
Mar 9, 2009 05:38 PM
william
Feb 27, 2009 07:31 AM
