1991 V6 Camry: Electric window and door lock not working
Old Jun 27, 2008 | 07:55 PM
mx3man83's Avatar
Default 1991 V6 Camry: Electric window and door lock not working
I found an electric manual online at camrystuff.com, but so far I've only skimmed through it briefly and have not found much as for solutions. I am going to test the circuit breakers, but other than that I'm not sure what to do. When I try to raise/lower the windows from any of the switches, nothing happens. When I try to use the power lock buttons, nothing happens. Help please. Thanks.
Old Jun 28, 2008 | 11:31 AM
Default RE: 1991 V6 Camry: Electric window and door lock not working
Check the wiring between the drivers door and chassis. Often the wires break inside the sleeve due to door usage causing these problems.
Old Jun 30, 2008 | 08:29 PM
mx3man83's Avatar
Will do.
Update: The windows work sometimes and sometimes they do not. The same for the power locks. However, the driver's window never works.
Old Jul 1, 2008 | 02:30 PM
The drivers side console incorporates both power window and lock controls.
Do the individual door window and lock switches work OK or just the driver's?
Keep in mind the doors have a power wire running to them that is separate from the one that powers the drivers console. Thus the individual door switches could work, yet the drivers console power wire have a problem.
Old Jun 23, 2009 | 07:28 PM
mysnickers's Avatar
I have a 1995 camry, its doing the same thing. I noticed one day that the locks worked when the door was open, but not when closed and then nothing, but it hasn't done it since. Did you solve your issue? Is it the wires connecting the door to the chassis? Or was it the window and door lock control in the drivers door?
Old Jul 4, 2009 | 11:24 PM
mysnickers's Avatar
Figured it out. at the feet of the driver is a panel that covers several plugs, I'm not sure how, but one of those plugs became loose over time. For me it was a 26 hour drive out to virginia. My only guess would be road vibration. But now I pushed the plug in, and wallaw everything works just fine. Windows, door locks, key unlock, just fine.
Robert Wolf
Sep 9, 2016 10:29 AM
TPSreports
May 13, 2015 08:31 PM
linsjean
Oct 11, 2012 09:44 AM
84runner
Aug 27, 2011 09:19 AM
vanlegr
Apr 26, 2008 11:03 AM
