1996 Camry V6 Problem
Old May 15, 2007 | 01:20 AM
redracer_13's Avatar
Default 1996 Camry V6 Problem
Hi,
I currently own a 1996 Toyota Vienta (the 4cyl were called the camry & the vienta was the V6 in aus) Auto.
In australia we never got the 1mz-fe engine on the gen 3's we were left with the 3vz-fe.
Well, the problem started a few months back......Sometimes i will start my car, put it in drive and every once in a while we may feel a small jerk/thud.. this happens when we are stationary at the lights, moving very slowly...i think its only 1's gear this happens but once i shift from drive to neutral then back the problem seems to go away msot of the time.
Everytime the car thuds the revs drop very slightly and then return. Sometimes the thud is harder than usual and other times it is quite frequent.
The car has done only 160000kms and we have cleaned the fuel filter and serviced the tranny (flush, etc.) and given it is general service within the last 1000kms.
Im hoping we dont need a new transmission or something & hope its only a small problem.
Any help will be appreciated
Old May 20, 2007 | 12:55 PM
toyoboy's Avatar
Default RE: 1996 Camry V6 Problem
did you happen to get the line pressure reading for your transmission...sounds like your accumilator springs or pistons my be at fault....
Old May 20, 2007 | 01:05 PM
toyoboy's Avatar
first things first..check trany fluid level..inspect throttle cable adjustment and make sure its not stuck in one position.
Old May 28, 2007 | 12:13 AM
driftinco's Avatar
Also inspect the engine mounts. A broken lower front mount may be causing the thud sound.
96cam
Mar 8, 2017 08:55 AM
keystone1979
Jul 9, 2011 10:39 AM
stubirdnb
Nov 21, 2008 01:17 PM
deepcdiver
Dec 23, 2007 09:23 PM
redracer_13
May 5, 2007 08:51 AM
