1999 Camry ignition switch
Old Jan 8, 2012 | 06:41 PM
spiman2u's Avatar
Exclamation 1999 Camry ignition switch
Steering lock issue-Who has replaced this? should b 2 pics from the key to the steering column Man this looks fun I have some plastic off Have not found this on line to buy. Just these 2 close ones on ebay-Help
Attached Thumbnails 1999 Camry ignition switch-%24-kgrhqj-hqe7r7cg8qnbo562kekpg%7E%7E60_3.jpg   1999 Camry ignition switch-%24-kgrhquokpwe25gr1mcfbn08yvkcc-%7E%7E0_12.jpg
Old Jan 8, 2012 | 07:10 PM
What are you replacing, the lock, steering column, both?
Old Jan 14, 2012 | 11:46 PM
spiman2u's Avatar
that is the pt. steering lock issues how far back....
Old Jan 15, 2012 | 12:23 PM
Still don't understand what part you are trying to replace.
The complete steering lock assy bolts the steering console via 2 tamper proof bolts. If you are replacing this assy these bolts need to be drilled out. Normally this assy does not have problems.
Sometimes there are issues with a worn ign key or lock. The lock cylinder can be removed without taking the steering lock assy off.
Johnjacobsen
Mar 14, 2015 08:45 PM
papatodd2010
Mar 13, 2010 11:06 AM
SIGNMAN
Jul 15, 2009 01:59 PM
machine
Jul 15, 2009 01:58 PM
thevillageidiot
Jul 12, 2006 02:03 AM
