2000 Camry LE - Passenger door lever busted...how do I replace it?
that's the easy part... popping off the internal pieces and removing the bolts/ two rods are tricky. Especially if the hex bolt slips and fall inside the door.. Remove the metal guard panel for easier access. stuff some rags inside in case you drop the bolts or that little yellow snap on piece.
thill2708
Apr 12, 2006 07:48 PM
