2000 Camry Power Window Problem
Old Aug 4, 2008 | 06:51 PM
Tommy D's Avatar
Default 2000 Camry Power Window Problem
Guys
My GFs 2000 Camry has both Front Drivers and Passenger side power windows sticking. It's worse in the summer time and normally happens when raising the window.
It only effects the front windows. Trying to lube the glass run with spray lube did not help.
So aside from changing the window motor/reg should I look for anything else?
Is this a Common problem?
Thanks!
Tommy D
Old Aug 4, 2008 | 09:10 PM
beunos24's Avatar
Default RE: 2000 Camry Power Window Problem
It has happened to my 92 camry. I replaced both motors and now my driverside is broken again.
Old Aug 5, 2008 | 10:20 AM
Have you lubed the regulator assy inside the door.
96cam
Mar 8, 2017 08:55 AM
Ricks
Jul 14, 2014 12:25 PM
jjwt
Aug 20, 2013 07:58 AM
whitecam
Jul 10, 2010 10:13 PM
mjgpe05
Jul 17, 2008 11:12 PM
