2001 Toyota Camry Car Troubles (danger!)
Old Jan 6, 2008 | 06:22 PM
bballsk8er333's Avatar
Default 2001 Toyota Camry Car Troubles (danger!)
Hi I am haveing trouble with my 2001 Toyota Camry LE 185k Miles, (most highway).
The front wheels squeel and hesitate and lock up when i turn sharp, especially when i dont give the car gas while turning. It seems to get worse as the weather gets cooler. I looked it up on google and some say lube, some say replace....but i just dont know. The problem is mostly annoying but i got scared when i went to turn on the road at +- 30 mph and it locked up .
Also, my breaks are grinding or sounds like (grind) smoothe (grind) smoothe when im driving, and when breaking constant grind. I think it may be the pads, but my bro is almost certain they are the rotors.
Thanks for the help.!
Old Jan 6, 2008 | 07:49 PM
OnE_To_HatE's Avatar
Default RE: 2001 Toyota Camry Car Troubles (danger!)
Thats too dangerous- have it checked out. Or Check the entire front axle yourself.
Old Jan 6, 2008 | 09:44 PM
sestivers's Avatar
Your brake noise sounds like the pads are worn past their useful life... if you don't get them replaced ASAP you will ruin your rotors, which will add a couple hundred dollars of parts to the brake job that you apparently need. But did you say that you also get noise when you're not applying the brakes? That would be unusual.
Old Jan 6, 2008 | 10:07 PM
Thanks for the ideas. I hear the sound erratically only like 1/10 of my driving time, sounds exactly lie the scraping but is random
Any ideas on the steering, thats my main concern.
W. Woodward
Dec 4, 2011 07:14 PM
damo
Jun 4, 2008 11:17 PM
Topher
Jan 14, 2008 01:11 PM
frogger
Jul 17, 2007 04:31 PM
