2002 Camry Battery/Starting issues?
Old Jan 2, 2012 | 10:31 PM
AgustinM1's Avatar
Default 2002 Camry Battery/Starting issues?
Hey i have a 2002 Camry , 4 Cylider. one day it wouldnt start, jumping didnt work. i charged the battery and jumped it and it did start. i bought a new battery but that one is now dead as well. do i have a short somewere ? anyone experience this problem ? Thank you for reading
Old Jan 3, 2012 | 12:33 AM
Might be excessive parasitic drain on the battery when engine is off or the alternator is not charging OK.
Recharge the battery completely.
The link below is one of many found on Google that describe how to check parasitic.
Battery Drain Parasitic Draw Testing
Check the trunk light to make sure it turns off when trunk is closed.
Check alt operation by measuring battery voltage between battery terminals with engine off and at 1500 rpm. Should be around 12.8v engine off and approx 13.5-14.5v engine on.
Old Jan 3, 2012 | 07:55 PM
ukrkoz's Avatar
ahmm, how about "dead battery 101" - cleaning cable terminals? also, if you have composite terminals, meaning - it's several separate pieces bolted to the cable - oh do they rust and lose conductivity!!
Diagnostic flowchart for a car that won't start or stalls - Troubleshooting for the starter, spark failure and the fuel pump
the desolate one
Sep 7, 2019 03:36 PM
hplar
Aug 15, 2013 06:13 AM
wmedani
Apr 9, 2012 10:01 AM
AgustinM1
Jan 3, 2012 11:55 AM
2007xle
Aug 7, 2009 09:50 PM
