2002 Camry Honk
Does anyone know what's wrong when the honk is out? Mine decided to stop working for some reasons. If there's a switch to turn it on or connect it, please let me know before I take it to the dealership for them to check out. Thanks!
There should be a fuse in the fuse box inside the car for the horn. Take a
look in there. Its the easiest thing to do. If that's not the problem, you may
want to try the other suggestion the other folks posted. I would personaly
try the easiest ones first and work my way back. Also, you can check the
horn under the hood and follow the wiring as far back as you can. maybe
something is loose or broke.
Good Luck!!
Good Luck!!
