99 Camry with little heat
Old Nov 11, 2006 | 05:00 PM
Jdale's Avatar
Default 99 Camry with little heat
I am thinking it might be the themostat that is not working properly but I don't have a ton of experience with cars. The car gets very little heat when turned all the way up and the engine temperature gauge barely comes off the bottom (cold). Any ideas? Thanks - J
Old Nov 12, 2006 | 05:14 PM
lavalleemike's Avatar
Default RE: 99 Camry with little heat
probably is the thermostat
Old Nov 13, 2006 | 12:25 AM
Jdale's Avatar
Thanks - John
Old Nov 14, 2006 | 03:08 PM
rolo12543's Avatar
Thermostat is a good suggestion. I had an identical problem with a Nissa pickup. Replaced
the thermostat and the tempature gauge rose to its normal position and I start getting my
heat back. Thermostats are relatively easy to replace and are pretty cheap. Just make
sure you get the correct one.
Good Luck!!
motmcd
Jul 8, 2014 04:51 AM
killaCAM94
Sep 22, 2008 09:49 AM
JBoivin
Nov 29, 2007 05:57 AM
gorak
Jun 5, 2007 02:21 AM
lavalleemike
Jul 12, 2006 02:45 PM
