2002 V4 17 MPG on City??
Old Jun 5, 2008 | 12:05 AM
RedCamryR's Avatar
Default 2002 V4 17 MPG on City??
Hello, I have a 2002 Camry SE V4 without any modifications and its getting about 17 MPG city on 89 unleaded.. is this right? I drive with low RPMs...
Old Jun 9, 2008 | 09:33 AM
kinzaamer's Avatar
Default RE: 2002 V4 17 MPG on City??
nah that’s not right at all, check your car air filter, when the last time it had its spark plugs, wires distributor cap, rotor, fuel filter changed? Lower rpm does mean anything, unless you are speeding off when the light turns green. Also every 30000 you should get fuel injectors and induction cleaned out. make sure you don’t have anything heavy in the car, any subwoofers, amplifiers will increase weight that can reduce the car mileage, the more weight the harder the engine has to work to run. if you are using 87 octance, adding a fuel additive, you can get STP 3 for 3 dollars from pep boys or advance auto, it will also increase your fuel milage and last but not least check tire air pressure. thats all i can think off, try any of these. see what you have done or not.
Old Jun 9, 2008 | 11:05 AM
pedro's Avatar
I doubt your year Camry has a distributor cap or rotor. The fuel filter should never need changing and is probably in the tank and inaccessable. On an 02 the wires and plugs should be ok as well, but I would check the air filter.Additives add little value on mileage. How many miles on this car? My 95 gets about 27 Hwy/City so 17 city sounds bad unless you idle a lot in traffic. Certainly weight and tire pressure are big factors. Are you sure no one is stealing your gas? Is your math correct? Pull the plugs and see if they appear to be running rich - a sign of too much gas to air.
Old Jul 2, 2008 | 10:40 PM
DeuceLee's Avatar
v4?????? i'd like to see that...you mean a I4?
anyways, my 02 I4 gets about 24 in the city and 38 on the hwy going 65...i use to go 75 and was getting 32ish...
xnleague
Aug 23, 2012 01:36 AM
minghe334
Sep 24, 2010 11:22 AM
werkit217
Apr 3, 2008 01:43 AM
c@mrycraze
Oct 24, 2005 04:05 PM
