2004 camry V6 3.0 (1MZ-FE) idling after cleaning
Old Dec 22, 2012 | 06:33 AM
Camry04's Avatar
Default 2004 camry V6 3.0 (1MZ-FE) idling after cleaning
Just wanted to share that I cleaned my throttle assembly with carb cleaner and wd40 and immediately had problems with my idling. First, the car wouldn't start after several tries. Then, once it started, idling would not go below 1,400 rpm even after driving several miles. Turns out, i needed to disconnect my battery before doing anything with the throttle assembly. The fix is, I disconnected the battery overnight and reconnected in the morning. All good now! No need to panic or bring to the dealer. Hope this helps!
Old Dec 23, 2012 | 02:43 AM
UhOh's Avatar
good info.
Hope you hang around and help again.
01camry09
Aug 19, 2011 09:51 PM
royjomo
Nov 8, 2009 07:46 AM
plkarie
Sep 23, 2008 04:42 PM
laredoggg
Sep 18, 2007 02:34 PM
marc780
Apr 10, 2006 06:22 PM
