2005 Camry Downshifting
Old Oct 25, 2005 | 04:03 PM
FormerGM's Avatar
Default 2005 Camry Downshifting
Purchased a used 2005 Camry about a month ago. Still getting used to it; a former lifelong GM owner. Have LE w/ 4 cyl automatic with about 8000 miles. Have begun to notice when I am going downhill at a speed greater than 45 mph and then begin to apply the brakes, when the speed drops to between 40 - 45 mph, there's a hard, very noticeable downshift - almost like it's dropping 2 gears. This occurs with Overdrive turned ON, and I've just begun to play around with the O/D off to see if there is a difference. Is this normal? Is there something that I can have the dealer check. Would appreciate any suggestions / insight. Thanks!
Old Oct 26, 2005 | 06:29 PM
Patrick's Avatar
Administrator
Default RE: 2005 Camry Downshifting
if youre that concerned with it, take it to the dealership, and check on TSBs or recalls.
Old Nov 1, 2005 | 12:20 PM
yianni's Avatar
My wife has a 2003 camry xle 4 cyl. and it does the same thing when you apply the brake when coasting or going a hill it does downshift. That is normal
Old Nov 1, 2005 | 03:00 PM
Patrick's Avatar
Administrator
excellent, thanks yianni
Old Nov 11, 2005 | 01:16 PM
OnE_To_HatE's Avatar
BACK TO THE DEALERSHIP! das their problem and not yours! ( it may be nothing because 05's have a 5 speed box but bring it anyways to have a piece ov mind.. ::SheAA!::
Old Mar 19, 2007 | 03:13 AM
05cam's Avatar
i just bought a 05 camry 4cyl and notice the same hard downshifting..I took a look at the tranny fluid and it was broken down.So i did a drain and fill to try and help. It seemed to help a little bit so im gonna continue to do a couple more drain and fills to clean it up nice. Other than that this car has been great so far. Fun on the highways with always plenty of punch on the gas. Impressive 4 cyl sedan by all means atleast.
Old Mar 19, 2007 | 11:12 PM
ron_aikins's Avatar
I went with my wife to the dealership just yesterday because the same phenomenon was bothering her. We have an '05 XLE. The tech was very friendly, drove it around with us in the car with him, & explained it was quite normal. The computer detects the slowing down & braking, so downshifts to assist. The computer does other things to improve fuel consumption, etc., & also tailors its behavior to how the car has been driven.
-Ron
my 2005 camry
Mar 18, 2013 03:28 AM
hlavender
May 21, 2007 08:41 PM
reynarob
May 15, 2007 10:11 PM
dassler
Mar 28, 2006 02:34 PM
KillaCam05
Feb 25, 2006 12:03 PM
