Browse all: Exterior
- Toyota Camry 4th, 5th, and 6th gen How to Install Windshielf Molding
2005 Camry XLE rear parcel shelf removal?
Of the various sources I had, none of them was totally correct or provided all the info I needed. Especially when it came to the rear shade area. I hoped that by posting and showing detail of the job on my car, that fellow owners may have another resource to add to the knowledge pool and get a better idea of how things are held in so they could do the job easier without, hopefully, damaging parts in the process. I hoped that the detail of the rear shade especially and its retaining clips, how they work and showing a good way to safely release the end clips with a simple tool, would prove helpful to others and again, reduce part damage potential.
Yours may be much easier if you don't have the shade.
Since I wrote my bit of a "how to" I now see there is a Youtube video that has been posted that might help you also. The video provides good info (maybe better than mine especially as I tend to be so long winded
), but hopefully my post still provides useful info, detail and useful pictures.Here is the link to the video to add to the knowledge base.
Best of luck with it!
Cheers
I assume you still have the stock head unit. No problem to use this to power the new rear speakers, but you may want to check the factory speakers ohm rating. The rating on mine were around 2 ohms if I remember correctly. Most aftermarket are 4 ohm. Without getting into a big discussion on the subject, basically what you may find is that by just replacing the speakers you will get (depending on speakers used) more detailed sound with better range ability, but it may not appear to give the same volume performance. Of course you can turn it up more than you usually do, but then you do chance getting into the realm of potential distortion. Basically driving the system into clipping.
Don't let me put you off doing the job though. I only mention as you may, depending on your ultimate goals for the system, consider adding an amp later. Cheers
srwhouston
Feb 12, 2008 07:09 PM
