2009 Camry SE driver door not unlocking
I have a 2009 Camry SE and about 3 weeks ago my key-less remote will unlock and lock all the doors except the driver side door. I have to lock and unlock manually. I changed the fuse to the door and replaced the battery in the remote. Has anyone had this same problem before? And what could be the problem? Thanks.
each door have power door lock actuator , if the actuator fail will not work electronically,but it will work manual.
do this test ?? does it work using the wireless transmitter?? --NO
does it work using the lock/unlock master switch on drivers door ?? --NO
if both answers are NO ,the actuator is bad .
pcumming
Nov 27, 2013 06:49 PM
eilros
Nov 13, 2007 09:00 PM
azizmak
Aug 2, 2006 09:22 PM
