87 Camry ? about the location of the ISC VALVE?
Old Apr 4, 2010 | 01:12 AM
hardyrxp's Avatar
Default 87 Camry ? about the location of the ISC VALVE?
Hello there,
Do you know where the Idle Speed Control Valve is located on my 87 Toyota Camry 5 speed 2.0? I ask this because I think it might be the cause of my idle problem that I did a recent post about on here? Please advise me as I can't find it thanks.
Dave
Old Apr 4, 2010 | 10:31 AM
Typically the valve bolts to the underside of throttle body. Has a couple of small coolant hoses running to it. The link below has a photo.
http://www.rockauto.com/catalog/moreinfo.php?pk=937877
Old Apr 4, 2010 | 10:45 AM
hardyrxp's Avatar
Default follow up
Hello there,
Thanks for answering back and that info. I did a cleaning of the throttle body so does that clean this part isc as well? There is a small hole in the throttle body in which it goes down to the isc does that clean that part as well?
Is there a way to clean the isc or should I just get a new one Please advise me here thanks.
Dave
Old Apr 4, 2010 | 11:06 AM
Yes, the small hole is the air intake for the IAC valve.
If you do clean the valve make sure the cleaner is safe for plastics, the valve is plastic.
Suggest you have the engine hot and running then spray into the hole a little at a time. The engine will want to die but keep it running by using the throttle pulley to keep the RPM up's.
To much spray and the engine will die and be hard to start until the fluid evaporates.
Some owners have removed the valve to clean it but this takes more time. Unless you find a used one the valves are not cheap. Thus suggest you try cleaning it first.
The Autozone website at www.autozone.com may show the procedure to test the valve. It has a small electric motor that can be tested by applying voltage.
Old Apr 4, 2010 | 09:29 PM
hardyrxp's Avatar
Thanks very much for responding back to my ?'s. I did clean it already and do what you suggested. The engine won't run with the plenuem off I tried it and it dies so I cleaned it throughly with the engine off and everything apart.
Dave
Old Apr 6, 2010 | 08:40 AM
The engine may have a MAF sensor preventing it from running with intake tube removed.
Old Apr 10, 2010 | 03:04 AM
lin_2008's Avatar
Yellow stone diesel parts plant is one of the leading manufacturers
of engine parts, in particular diesel fuel injection system
accessories for replacement, such as Fuel injection Nozzle, Plunger and
Delivery valve, ETC In south of china .
for more detail please visit our website : www.yellowstonediesel.com
www.dieselinjection.cn
Yellow stone diesel parts plant was founded in 1997.Over the years,
Yellow stone has grown and gained a reputation for producing
high quality products and delivering them on time.
105015-5860
105015-5860
105015-5940
0 433 171 134
0 433 171 137
0 433 171 146
5611065 H60S30A538
5611650 BDL110S6133
5611735 BDL110S6267
6801082 6801082
6801087 6801087
6801088 6801088
DN10PDN130
DN0PDN121
HL176S27D525P2
2418455518 2455-518
2418455714 2455-714
9401087506 9087-506
134151-4120 P121
134151-4920 P129
134151-6420 P143
NOZZLE DENSO 093400-7690 DN10PDN129
NOZZLE DENSO 093400-7700 DN10PDN130
NOZZLE DENSO 093400-8220 DN0PDN121
131110-9320 131110-9420 131160-0320
hardyrxp
Mar 26, 2010 09:28 PM
ezekielguy86
Jan 7, 2009 12:37 AM
camrycoupe
Sep 3, 2007 12:12 AM
jasonrobinette
Dec 26, 2006 10:13 PM
crazybabyinky
Feb 15, 2006 05:09 AM
