EGR Valve Location
Old Jan 6, 2009 | 09:10 PM
ezekielguy86's Avatar
Default EGR Valve Location
My engine light came on and I was told it was the egr valve. I just need to know is it the one on the left or right. I wanna take it off and clean it see if that helps. Also it will take awhile to get the gasket will it be ok to use the old one till the new one comes thanks
Old Jan 6, 2009 | 09:58 PM
Default RE: EGR Valve Location
I guess I should state its a 96 2.2L sorry
Old Jan 6, 2009 | 10:16 PM
Go to the Autozone website at www.autozone.com. The site has vehicle repair guides that should provide good info on the EGR.
EGR cleaning is very common, do a Google search on our engine type. A 5S-FE.
As long as the old gasket does leak it should be fine.
The EGR valve is closest to the drivers side. The EGR modulator is closest to the passenger side. The VSV is behind the engine.
Suggest checking to make sure the VSV, modulator, etc is working. Often the VSV valve goes bad.
Old Jan 6, 2009 | 11:53 PM
Ok now does anyone know the easiest way to get the bottom metal hose off the valve it looks tricky. thanks
Old Jan 7, 2009 | 12:37 AM
Some folks have removed the throttle body for better access. Or try going in from under the car with a long extension and a few swivels joints.
toyotafan111
Jul 21, 2017 01:20 PM
treonn
Jun 23, 2009 02:37 AM
KennyCoe
Mar 24, 2009 08:43 PM
firstforme
Jul 20, 2008 09:27 AM
camrycoupe
Sep 3, 2007 12:12 AM
