91 Camry ran without oil
Old Oct 5, 2005 | 12:52 PM
CKSAMartin's Avatar
Default 91 Camry ran without oil
I've got a 91 Camry 4 cyl, with almost 200,000 miles on it. Yesterday, the engine stalled as I was driving, then restarted and made a loud banging/rattling noise. Reminded me of the bad gas rattling noise cars make but louder.
Turns out the car had run out of oil, and the warning light didn't go off. Luckily, the car had been slick 50'd a while back and I always add duralube etc with changes. I drove home for about 40 miles. Car idles okay, with no noise, but when revved the rattling/banging noise sounds off. No loss in power, all 4 seem to be firing.
Anyone have any ideas about what I've done to it? Father in law thinks I damaged a rod or two. I was hoping it was just something in the valve area of the engine so I could fix it myself.
If I can't fix it, I sure will miss this little car.
Old Oct 5, 2005 | 04:49 PM
Patrick's Avatar
Administrator
Default RE: 91 Camry ran without oil
my guess would be that you ruined a rod bearing...im guessing that you have since put oil in it? does it run ok?
Old Oct 5, 2005 | 05:23 PM
CKSAMartin's Avatar
I put 3 quarts in it and it runs fine- just noisy. At idle speed there's no noise, but revving the engine makes for some rattling/banging.
Pretty neat the engine didn't seize. Since there was no sudden leak of oil, I guiess it's been running low for two months or more.
Old Oct 12, 2005 | 02:15 PM
Patrick's Avatar
Administrator
well, good luck...i would find a good mechanic...
Old Apr 10, 2006 | 07:08 PM
marc780's Avatar
Yes its too bad, i blew up an engine once from overheating. 1985 Nissan 200sx. It broke a piston.
Sounds like it needs a new engine
Odstoro
Jun 26, 2014 11:49 AM
KEVAUG
Dec 10, 2012 10:50 AM
Sonny
Jul 19, 2011 09:31 PM
XLEV6
May 14, 2009 04:28 AM
GrillZ
Oct 8, 2006 02:58 AM
