92 auto gear problems
Hi.
My car does not go over 2000rpm before going into the next gear (except in o/d)and does not downgear. When the car gets hot though the gears does notchange until about 3200rpm. Can anybody help me with gear problems?
Thanks.
Thanks.
RE: 92 auto gear problems
I monitor it closely. When I got the car, the trans fluid was overfilled so I drained some toget the right level on the dipstick. I replaced the waterpipes on the car and have had this problem ever since. The trans fluid is cooled at the bottom of the radiator, so it might be the trans fluid.Is overfilling a big problem?
Make sure the trans cooler on the radiator is actually hooked up to the trans.
Check the throttle position and vehicle speed sensors plus wiring and that the trans PWR switch is not engaged.
1/4 to 3/8 inch overfill on the dip stick is 3-4 oz which will not cause problems.
Check the fluid when hot, engine running after shifting through all the gears and back into Park.
ORIGINAL: Upscaletiger I replaced the waterpipes on the car and have had this problem ever since.
