92 camry driver window doesn't work
My driver side window doesn't work anymore and just my luck during summer when I need it the most I had the motor replaced and it broken again has anyone else experienced this problem?
Window motors do not typically fail on Camry and two in a row is unusual. Is the window binding on something?
Might check the wiring between the door and frame. The wires inside the sleeve can break from door usage.
I took the door panel off and checked to see if any wires were in the way and I didn't see anything snagging the window. I got that motor off of a totaled camry and it worked fine for about 6 months but then it would stop half way and I had to slam the door and hold the button for it to come back up. I can't get a great look inside the door cause there is way to much metal in the way. I think I'm gona have to check with a mirror and see if it does any good. If not then I guess I'm going back were I got the motor but I don't really trust them they might try to take my speakers
