Sony Radio Doesn't Work
Old Nov 22, 2010 | 10:51 AM
drjeep1959's Avatar
Question Sony Radio Doesn't Work
I just bought a 95 Camry LE. The car came with a Sony stereo installed with an in-dash CD player and AUX inputs for an MP3 player. Everything works on it except for the radio. The antenna will go up when radio is selected so I know that part's properly connected, but all I get is static. What could be causing this? Thanks.
Old Nov 22, 2010 | 11:12 AM
The antenna motor has its own power wire. The motor can run without larger antenna cable being connected to the radio.
Find out if the antenna cable is connected at the radio and antenna. To access the antenna remove the trunk liner on the side of antenna.
The link below may provide info on accessing the radio.
The cable plugs in at each end.
www.installdr.com
MrKeith
Feb 2, 2016 03:14 PM
Jlfrias
Dec 31, 2014 12:53 PM
Santanica
Feb 13, 2012 10:25 AM
bkpez
Apr 17, 2011 09:34 AM
beunos24
Jul 8, 2008 04:01 PM
