'94 Camry 1MZFE - poor acceleration, engine stall, bad coil?
Old Oct 15, 2012 | 03:59 AM
Huo Yuanjia's Avatar
Question '94 Camry 1MZFE - poor acceleration, engine stall, bad coil?
So I've scoured the camry forums and seen issues like mine: won't accelerate quickly, when I press the acceleration pedal the engine will cut out before it reaches 3000 rpms, sometimes it runs smooth other times a rough idle. I want to check my coil but I dont know how. How do you check the coils resistance for this particular camry and where would I even find the operating numerical resistance values? Thanx!
Old Oct 15, 2012 | 08:36 AM
grizlbr's Avatar
Default On line manual check distributor
http://www.turboninjas.com/camry/eg1.pdf Would be a good place to look or Autoz0ne online repair help distributor enter Camry 94 6 cyl procedure is same for 5SFE. I have been to too many sites: do not know if I will get a demerit if I post direct link to autoz. Or that you can use my direct link with out being logged in? Will see? While you are waiting read about reading error codes with engine light TE/T1 TO E1! One starts key on the other key off!
Old Oct 15, 2012 | 08:44 AM
grizlbr's Avatar
Ii have looked all over this was helpful. Mods if I am not sposed to do this please let me know it is what came up on googgle with my specific search.
Search Results http://www.autozone.com/autozone/rep...00c152801cc971 <this works!
  1. | Repair Guides | Electronic Spark Advance System ... - AutoZone
    www.autozone.com/autozone/repairinfo/.../repairGuideContent.jsp?...
Old Oct 21, 2012 | 01:58 AM
Thanx so much! Thats a lot of info there but very useful. I'm sure I'll be able to troubleshoot accordingly. Thanx again!
uteeputz
Apr 11, 2014 07:16 PM
1995YotaCamry
Oct 17, 2009 05:38 PM
niccisweet
Nov 4, 2008 07:05 AM
veesix
Apr 6, 2008 06:49 PM
fixitguy63
Mar 28, 2008 07:34 PM
