engine running rough, poor idle
Old Nov 4, 2008 | 05:48 AM
niccisweet's Avatar
Default engine running rough, poor idle
i have an 89 LE V6 w/144,000 mi on it. when i bought it the engine pulsated and it died at idle (sitting, at stop signs etc). the radiator had been replaced and a tune up done, but the there was still stop leak in the coolant and it had two engine codes, both rich and lean fuel codes.The heater core was plugged too..We flushed the coolant, connected a vacuum hose or two, did a Bearyman's flush through the intake and the pulsating improved, the codes went away, and we get alittle heat, but when the car gets hot, (high rpms, extended idle) the pulsation comes back and occasionally so do the codes. It seems to run better in cold weather as well. there don't seem to be any other significant problems, but it does gets poor gas mileage. the exhaust is rotted, but it is behind the 02 sensor. we're kinda stumped at this point. anybody have some suggestions or ideas about how to fix her? any help would be appreciated. thanx....
Old Nov 4, 2008 | 07:05 AM
Default RE: engine running rough, poor idle
Idle speed is adjusted with the IAC valve via the computer. Perhaps it needs cleaning. A Google search will turn up lots of info on this valve.
How does the engine idle and accelerate, OK. Does the engine die when the throttle is pressed or when the throttle is let off?
Are you taking about the engine warming up or getting hot as in overheating?
Is the engine idle OK when cold but not warm?
Might review past posts at the bottom of this page.
shloho
Jun 12, 2010 03:51 PM
PharusCustos
Aug 19, 2009 04:25 PM
jackkpts
Jul 18, 2009 07:23 AM
infernocl
May 8, 2008 12:46 AM
62 chevy
Jul 19, 2007 04:22 PM
