95 camry not getting any power to fuel pump
Old Dec 17, 2013 | 04:57 PM
miltontl's Avatar
Default 95 camry not getting any power to fuel pump
95 toyota camry 4 cylinder not getting any power to fuel pump. To start i was driving came to a stop sign and the car died, i cranked it back up and it ran for a second or two then would not start anymore. I was not getting any fuel so i replaced the fuel pump and strainer. Still not getting fuel i found that i was not getting any power to the pump. I was told it was the circuit opening relay, so i replaced it still not getting any power at the pump. also i did the fp b+ test still no power to pump. I have ran out of money and dont know what else to do. Any help would be greatly appreciated
Old Dec 17, 2013 | 05:35 PM
Is the car getting any power, main fuses not blown?
Jumping the B+ and FP terminals in the small box WITH ign switch ON and still no power at the fuel pump wire?
FP terminal in small box goes to same terminal on Circuit Opening Relay that the fuel pump wire goes, thus if B+ and FP jumped, pump would be powered directly.
Wire colors are pump 12v power Blue/Black, pump ground White/Black.
If you have a voltmeter check for + 12v DC at B+ terminal in box with ign switch on. If no power may have a fuse problem.
Can apply +12V DC directly from car battery to the FP terminal to check for pump operation. If doing this be careful not to touch any other terminals. If pump runs the wiring from the Circuit Opening Relay to the pump is OK along with pump. If not there is a problem.
If no B+ power check the following, EFI relay, EFI and AM2 fuses. The EFI fuse also powers the fuel injectors.
Old Dec 17, 2013 | 05:49 PM
miltontl's Avatar
b+ has power when jumping b+ Fp, still no power at the pump
Old Dec 17, 2013 | 08:30 PM
B+ terminal receives power from same power source as a terminal on Circuit Opening Relay (COR), Black/Orange (No 2 terminal). If B+ has power the EFI fuse and EFI Relay should be OK.
With B+ and FP jumped, ign on and B+ has power, power should go to a terminal at the COR (No 1) from this terminal to the pump bypassing the COR.
If B+ and FP are not jumped, when COR is powered (closed) the power at terminal 2 should go through the COR switch to COR fuel pump terminal (No 1), then to the pump (Blue/Black wire).
The COR should be powered (closed) when engine cranking over or running but not when ign switch is just in on position.
Check for power at the above COR terminals under the conditions listed.
If Ok the problem is between the wiring between the COR and fuel pump.
Make sure you are testing voltage in the wiring between the test source and good chassis ground.
Also make sure the new pump operates by applying voltage directly to the pump as installed in take. Blue/Black wire is +12, White/Black ground, or what every wire color the pump uses.
Old Dec 18, 2013 | 10:51 AM
miltontl's Avatar
i just checked
with the ignition on i have power at the orange/black wire, but no power leaving with the blue/black wire at the circuit opening relay, (this is without the jumper on b+ and fp) no power at pump
with the igniton on and jumper across b+ and fp terminal i have power at the blue/black wire at circuit opening relay, still no power at pump
Old Dec 18, 2013 | 03:55 PM
Engine needs to be cranking over or running for circuit opening relay to close and power flow from the Orange/Black wire to Blue/Black wire.
If power at Blue/Black wire when jumper used then for some reason this power is not making via the Blue/Black wire to the fuel pump. There are a couple of junction boxes in this wire to the pump. One appears behind the drivers side kick panel, the other near the fuel tank, likely the connection to the fuel pump.
Make sure the plug at the pump is OK and not damaged.
Make sure the pump actually works when directly powered.
Worst case and run a wire another wire from the circuit opening relay to the pump down the drivers side of the rocker panel where the main harness runs on this side of the car. But a cut wire would be unusual.
Old Mar 28, 2015 | 07:33 PM
Roger Faircloth's Avatar
So I have a similar problem. But when I jump b+ to fp I do get power to fuel pump and it runs. But the engine does not start.
I have changes relays, fuses etc, cap, rotor.
Old Mar 28, 2015 | 08:54 PM
Year of car and engine type, V6 or 4 cylinder?
Have you checked for ign spark?
Old Mar 28, 2015 | 09:17 PM
95 camry 2.2 engine. I did not check for spark yet
Old Mar 29, 2015 | 11:07 AM
Check for spark.
