95 camry not getting any power to fuel pump
Old Mar 29, 2015 | 04:04 PM
  #11
Roger Faircloth's Avatar
no spark either with the jumper or without.
Old Mar 29, 2015 | 06:02 PM
  #12
Check for +12v at the white/red wire to the coil (or distributor) and igniter, ign switch on.
Remove the dist cap and determine if the rotor is turning when engine is cranking over.
Old Mar 29, 2015 | 07:40 PM
  #13
power to white/red wire. rotor does not turn
Old Mar 29, 2015 | 11:27 PM
  #14
If rotor does not turn, timing belt is broke. Need to replace this.
Old Mar 29, 2015 | 11:32 PM
  #15
thanks
Old Apr 5, 2015 | 04:05 PM
  #16
timing belt replaced. ran better than ever for two days. started missing on the way to work then died.
Rotor turns but no spark. I did jumper the fuel pump to be sure that worked. any ideas?
Old Apr 5, 2015 | 04:26 PM
  #17
What condition was the old timing belt? Broken, teeth missing or ?
If no spark then no point for now investigating the fuel pump. The pump operation at engine crank over is not linked to spark but the operation of the starter motor system.
Is the ign coil built into the distributor (Federal) or external (California)? If built in the distributor cap it would have 4 spark plug wires but no coil wire.
Did you again check for 12v power at the wires suggested before?
Use the link in the private message to test the ign system.
Old Apr 5, 2015 | 04:52 PM
  #18
Broken timing belt Coil must be built into distributor. 4 wires to plugs only.
I did notice some oil in distributor cap. Cap is new. Still has power to white/red wire to distributor etc.
Old Apr 5, 2015 | 06:44 PM
  #19
If oil in the distributor, the distributor drive shaft seal could be bad. The internet has posts on replacing the seal plus finding a seal kit. Look under "5SFE distributor shaft seal".
Use the diagnostic info in the link provided in the private message. Check the sensor coil resistance and make sure it is within range and does not vary with time. Meaning you take a reading with an ohm meter and the resistance is not fixed, but starts to change, typically increasing.
joea
Jun 30, 2014 10:25 PM
Bam Bam 65
Oct 20, 2013 05:54 PM
hboemer
May 4, 2012 05:44 PM
KEVAUG
Mar 17, 2012 12:19 AM
camaropoor
Jul 23, 2010 10:16 AM
