95 Camry Question.
Old Apr 5, 2010 | 10:36 AM
chucho1026's Avatar
Default 95 Camry Question.
i have a 95 Camry that is giving me trouble starting on a cold start. after several attempts it starts and i dont have the same problem again until i leave the car sitting for a while. Any Suggestions?
Old Apr 5, 2010 | 03:09 PM
vietpho's Avatar
You might need a new battery.
If you have a volt meter, check the voltage of your battery before you start it. If it's below 11.5, you most likely need a new one
Old Apr 13, 2010 | 12:48 PM
chucho1026's Avatar
wouldn't it be a slow crank if the battery was dead? in my case its not a slow crank it sounds normal, it just doesn't want to start. but when it does it stalls a few times and turns off, then i trying again and it starts perfect.
Old Apr 15, 2010 | 12:48 PM
chucho1026's Avatar
it was the coolant temp. sensor. it acutally doubles as a cold start injector sensor
