97 V6 valve stem seals
Old Feb 9, 2010 | 06:43 PM
Winger95's Avatar
Default 97 V6 valve stem seals
I have recently acquired a 97 Camry with a V6 that smokes quite a bit when it is first started. I am going to replace the valve stem seals as soon as possible. Most cars that I have worked on in the past basically have O-rings for seals. Is this the case with this V6?
It was always possible to buy 'umbrella' seals as a replacement to get a better seal around the valve stem. Does anyone know where to get these types of valve stem seals? Part numbers?
Old Feb 9, 2010 | 07:34 PM
The engine would use a lip seal contained in a metal retainer. See link below:
http://www.valveseal.com/images/t30e.jpg
Not sure umbrella seals would fit.
You can change the seals with the heads on the engine but it takes a lot of work.
http://www.mkiv.com/techarticles/valve_stem/index.html
tricky.bob
Jan 19, 2024 11:31 PM
scrap wire
Feb 4, 2020 08:32 PM
pederpod
Aug 2, 2011 01:25 PM
ofersha
Jul 8, 2009 05:56 AM
Hemiman
Oct 1, 2007 03:44 PM
