98 2.2 Erratic Idle
Old Sep 4, 2007 | 06:37 PM
MTPolaris's Avatar
Default 98 2.2 Erratic Idle
My 98 5sfe 2.2L autohas a very bad erratic idle. The head was recently rebuilt with new timing belt, tensioners,water pump, gaskets, plugs, wires, oil and air filters, coolant, drive belts, and the intake andthrottle body were cleaned.
The problem is when coming to a stop the idle starts pulsing between about 600 and 800 rpms. It seems worse when the engine is cold. The only codes occasionally I getareP0300 and P0303 the multiple misfires and the misfire on cylinder 3. If I shift the tranny into neutral it goes away for the most part. When its in drive it shakes the engine, and it feels like the car is trying to move harder than normal. The idle's not as bad in park. The fluid and tranny filter were just changed as well.
The engine doesn't seem to burn any oil and it looks very clean.
Could this be a vacuum problem? Any ideas? Thanks for the help.
Old Sep 5, 2007 | 05:49 AM
pedro's Avatar
Default RE: 98 2.2 Erratic Idle
Since you already replaced plugs and wires I'd start with the other usual suspects - leaking EGR and/or vacuum leak. Also make sure the plug wires are connected properly. I assume this happens with or without A/C on? Cleaning the IAC would not hurt as well.
Old Sep 5, 2007 | 06:22 PM
MTPolaris's Avatar
Pedro thanks for the reply. I checked the egr valve per the instructions in the chilton manual and it checked out fine. When the A/C is on it really bogs down the engine. The wires are connected in the right order. I tried checking all the vacuum lines for cracks or anything that may be leaking and found nothing. How do I go about cleaning the IAC?
Thanks
Old Sep 5, 2007 | 09:16 PM
pedro's Avatar
So do you mean the idle problem isONLY with A/C running? If so there is a problem with the idle-up circuit.
Old Sep 6, 2007 | 04:50 PM
MTPolaris's Avatar
The idle problem happens all the time, worse when cold and itgets evenworse with the A/C running. The A/C almost kills the car when coming to a stop.
Old Sep 6, 2007 | 05:30 PM
pedro's Avatar
ORIGINAL: MTPolarisHow do I go about cleaning the IAC?
There's a lot of posts on this. Just do a search and you shouldget all the info you need. Since you had the TB done this problem may relate to timing so I would also get the engine timing checked out. I don't know if you can even adjust the spark timing ona 98 but if you canI would seehow far it is adjusted as that may tell you that the mechanical timing was not set accurately. If it's easy to remove the upper timing cover to see thecam timingmarks I wouldthe align the crank timing mark to TDC compression and see how the cam marks line up.
Old Sep 9, 2007 | 09:57 AM
cali714guy's Avatar
i would check you intake manifold it can be cracked and it is sucking air and misfires...i have an 00 mitsu galant and i had to swap my intake manifold because it was cracked and it idled to high and then it got worse and wouldnt idle at all it would turn off. any how check you "intake manifold" especially where the throttle body connects. Also it can be that whoever messed with the throttle body moved the to tps sensor.
camry114
Mar 22, 2021 10:57 PM
evidinhajr
Aug 11, 2017 12:19 AM
Hightshoe
Nov 25, 2011 01:12 PM
carl455
Oct 20, 2010 10:13 PM
jmhowe
Oct 24, 2006 03:49 AM
