Browse all: Lighting Guides
- Toyota Camry 4th gen Why Aren't Reverse Light Working
Guide to diagnose trouble and recommended solutions
98 camry reverse lights not working
my reverse lights are not working either. I used a test light and have powerat both wires coming into the bulb even when not in reverse. Any ideas on where I should start I am assuming there should not be power at both terminals without the car in reverse. Any help would be greatly appreciated. I checked the fuse #22 it was fine and both bulbs are fine.
actually they won,t go on. sounds weird I know but bulb filament is intact. Auto transmission. going to try and change the bulbs and see but am I correct in assuming there should not be power until car is put in reverse?
I believe that power always on is correct. If not then you would havelightsalways on now as a circuit will have been completed. The reverse switch should ground the circuit and that actuates the lights. You should check out your park/neutral position switch. That's where the reverse light switch is. It mayjust need adjustment or you have a broekn wire. Try putting the shift lever in R then wiggling it while someone looks in the rear for the reverse lights to come on.
Edit: I had a chance to look at my electrical manual. Power goes through the park/neutral switch and the bulbs are grounded to the chassis in the rear, at least on my 95.Only way it seems for power to be always on is if park/neutral switch is faulty. The fact that you always have power to bulb but lights won't work would be bad ground or wrong/bad bulb. I think you need to solve the bulb not on first, then tackle the park/neutral switch.
it might not be your lights at all. On my 94, the lights don't come on when i go into reverse because the sensor doesn't realize the cars in reverse. When you Put it in reverse, does the R on your dash light up? I have to wiggle the shifter to get that light to come on, and then the reverse lights come on.
I also have this problem. Occasionally the R light on the dash will come on when the shifter (automatic) is wiggled. When the R is on, then the reverse lights come on.
Also don't have D or N lighting up. Though sometimes I have N come on at the same sort of time as the R (ie, when the R is in a working mood, then the N generally is too)
How do I get to the shift sensor... ? Is it difficult and should I get a haynes manual so that I can do the work?
Is it a job for a handy guy, or a garage?
Dave
Dave
artnsf
May 24, 2011 01:01 PM
